Powdercoating 2004 YZ 250 frame?
Have a 04 YZ 250 (steel frame) that I'm rebuilding and I'm curious if I can powdercoat the frame without having any troubles with the PC screwing up bolt holes and things like that in the frame.
Anyone have any tips or have done this before? Never had anything PC before so thanks in advance!!
-Cody
If you are taking it to someone to have it done, they should protect your threads without u asking, it wouldn't hurt to mention it to them when you drop it off however. If some PC does get in your threads, a tap usually clears it right up. Also ask them about HD (heavy duty) powder. It is a lot more scratch/chip resistant. If you need an odd color that doesn't come in hd, they can put a hd clear over your color with the same results.
Pm if I can help in any way
