v757b Posted April 10, 2010 Made a video for you all. http://www.youtube.com/watch?v=DT75I9gzu8U How do you suggest I fix it? I'm guessing I messed up the threads in the frame. Neither of the bolts do what they are supposed to do. 👍 Any help is greatly appreciated. Thanks! Share this post Link to post Share on other sites
Johnny_On_The_Spot Posted April 10, 2010 cross threaded Share this post Link to post Share on other sites
v757b Posted April 10, 2010 cross threaded How do I fix that? Share this post Link to post Share on other sites
driedupmotocrosser Posted April 10, 2010 if possible run the bolt in from the other side of the hole ie backside of the frame all the way out till the threads of the bolt are showing use some light oil when you come to the rough spot in the threads work the bolt back and forth you should feel the threads lossen up a bit go to the hardware store and buy yourself some metric taps if nesscessary should be a m6 tap GOLDEN RULE always start bolts and nuts by hand make sure theyre threading in straight before you apply force grasshopper !!! Share this post Link to post Share on other sites
v757b Posted April 10, 2010 if possible run the bolt in from the other side of the hole ie backside of the frame all the way out till the threads of the bolt are showing use some light oil when you come to the rough spot in the threads work the bolt back and forth you should feel the threads lossen up a bit go to the hardware store and buy yourself some metric taps if nesscessary should be a m6 tap GOLDEN RULE always start bolts and nuts by hand make sure theyre threading in straight before you apply force grasshopper !!! Thanks a lot! And just when I had enough money to get my wheels powdercoated. 👍 Share this post Link to post Share on other sites
cr 250 Posted April 10, 2010 yeah always make sure with any bolt that its threaded right before tighnening as said use some oil and be patient make sure the thread it clean before putting it in Share this post Link to post Share on other sites
Nighthawk016 Posted April 10, 2010 if possible run the bolt in from the other side of the hole ie backside of the frame all the way out till the threads of the bolt are showing use some light oil when you come to the rough spot in the threads work the bolt back and forth you should feel the threads lossen up a bit go to the hardware store and buy yourself some metric taps if nesscessary should be a m6 tap GOLDEN RULE always start bolts and nuts by hand make sure theyre threading in straight before you apply force grasshopper !!! WHOA WHOA WHOA.... I may only be 18 BUT!! if you can pull that bolt back out and it's not screwed... just take it in to your local hardware store, get the correct tap and re-tap the hole with that, not that bolt. And I believe that is an M8 not an M6, M6 is much smaller, like what you would use to secure your plastics. 👍 Also, I agree with that last part, start it by hand, and if it gets stuck take it back out and start over. Share this post Link to post Share on other sites
1.21GW Posted April 10, 2010 Yeah re-tap and you should be good to go. Taps aren't hugely expensive chances are you will need the same one again down the line anyways. Just sucks when you do that sort of thing before a ride and the stores are closed. 👍 Share this post Link to post Share on other sites
driedupmotocrosser Posted April 10, 2010 WHOA WHOA WHOA.... I may only be 18 BUT!! if you can pull that bolt back out and it's not screwed... just take it in to your local hardware store, get the correct tap and re-tap the hole with that, not that bolt. And I believe that is an M8 not an M6, M6 is much smaller, like what you would use to secure your plastics. 👍 Also, I agree with that last part, start it by hand, and if it gets stuck take it back out and start over.[/QUOte listen to nighthawk hes apparently the professional maybe he likes to cross thread his bolts too. hey professor whats the thread pitch on those m8 bolts?? 🤣 Share this post Link to post Share on other sites
v757b Posted April 10, 2010 Actually, driedupmotocrosser's method worked. Thanks! I just screwed it from the back (insert "that's what she said", or "he said" joke) and it was a little hesitant at first but I kept going. I backed it up, then put it through the other side and worked like a charm! I used good ole' WD-40. Thanks again for all the help! Bike is back to normal and waiting for the rims to be powdercoated soon. Share this post Link to post Share on other sites
klxd Posted April 11, 2010 That was better than retapping. Running a tap through from the damaged side would likely have been crossed too and ruined the hole. Share this post Link to post Share on other sites
R.D. Posted April 11, 2010 Bike is back to normal and waiting for the rims to be powdercoated soon. Damn right, thats what Id do. Get my rims powdercoated. Screw buying tools and learning to use them. Share this post Link to post Share on other sites
moto_x2005 Posted April 11, 2010 you know you can make a tap as well if needed.. take a bolt thats the same threat pitch and diameter and cut two grooves on the end of it (opposite then each other) and thread it in Share this post Link to post Share on other sites
Nighthawk016 Posted April 12, 2010 WHOA WHOA WHOA.... I may only be 18 BUT!! if you can pull that bolt back out and it's not screwed... just take it in to your local hardware store, get the correct tap and re-tap the hole with that, not that bolt. And I believe that is an M8 not an M6, M6 is much smaller, like what you would use to secure your plastics.🤣 Also, I agree with that last part, start it by hand, and if it gets stuck take it back out and start over.[/QUOte listen to nighthawk hes apparently the professional maybe he likes to cross thread his bolts too. hey professor whats the thread pitch on those m8 bolts?? 🙂 Better safe then sorry, and i meant only to give him sound advice... because your idea will only work SOME of the time... no need to say im a know-it-all... when i know i know very little. I just didn't want him to destroy that sub frame mount just because there was a faster way to do it then the way i suggested. and i'm not sure on this... but it may be a 1.25 or a 1.5 for the thread pitch.... 👍 Share this post Link to post Share on other sites
Johnny_On_The_Spot Posted April 12, 2010 Subframe bolts are M8X1.25 btw 👍 Share this post Link to post Share on other sites
