07 wr250f
Search this forum for the things known as "free mods".
They won't all be free, but definitely worth it because the way your WR rolled off the showroom, it's green sticker plugged up and not running to it's potential at all. ­čĹŹ
It is possible that the dealer may have already swapped out the throttle stop but other things such as disconnecting the gray wire, AIS removal kit, jetting, exhaust, hot cams and some other things but you are still going to have a heavier bike than the yz but with these mods the bike really wakes up!
First things I did was the AIS removal kit, exhaust mod, ACC pump, idle screw and gray wire and its a totally different animal!
The bike is quite different to the YZ. It has a heavier fly wheel etc.It is a better trail/ST bike than the Yz. Basically a new pipe and a jetting kit will get the best out of her without going to the expense of head polishing, yz valves etc. They are an honest, terrific and reliable trail machine. The big bore kits are supposed to be good with several sizes up to about 290 cc's on the market.
├Ś
├Ś
