FCR-MX wideband tuning - Another FCR needle question
At idle I get a air fuel ratio of 13.2 and its great until I just about reach 1/4 throttle where the AFR shoots up to 16.2 (noticeable power loss too) and stays lean very briefly up to 3/8 throttle where it drops right back down to 13.2 AFR. From 3/8 to WOT the AFR is great. I tried different clip settings but that affects the whole AFR between 1/4 and 3/4 throttle. If I understand correctly the L1 dimension in the sudco literature is the length measured down from the clip end of the needle and is the point at which the taper starts? I am correct? Does this move the whole taper upwards as it does when you change clip position or does the taper stretch (get longer)? I'm hoping the latter. I was thinking maybe an ELR needle or EGR needle if the taper gets stretched. If all it does is shift the taper upwards like you would change a clip position then changing the L1 dimension will not help me. In that case I might have to try a smaller tapered DMR or DLR.
To me the taper is fine but I think the straight part of the needle lasts slightly too long.
I have been doing some needle comparisons with the JD Jetting guide spread sheet that I purchased and have determined that in fact changing the middle letter is the same as changing clip position. Also changing the taper E to a D from the spread sheet will probably affect my AFR too much. Instead I would like comments on the NCVR needle which incorporates a 2nd taper that acts from 1/8 throttle to 3/8 throttle but has the same final taper as the EMR. It would seem that this needle might fix my lean condition that I explain in my previous post above. If anyone has comments I would appreciate it.
i think you are still on the straight diameter of the needle. didn't i see another post where you tried the EMN? did this affect that issue?
Thanks for responding. Yes I tried the EMN needle but the same lean condition existed although it peaked to a lesser extent, see below
EMR
throttle - AFR
0 - 13.2
1/8 - 13.2
between 1/8-3/8 - 16.2 peak
3/8-1/2 - 13.2
1/2- 3/4 - 12.8
WOT - 11.8
EMN
throttle - AFR
0 - 11.8
1/8 - 12.0
between 1/8-3/8 - 15.2 peak
3/8-1/2 - 13.0
1/2- 3/4 - 12.6
WOT - 11.6
Please note that I am still using a 38PJ and 100 PAJ in both cases and I have no main air jet. The air screw is set at 2-1/4 turns out with the EMR needle and 1-1/2 turn out with the EMN to achieve proper pilot circuit tuning.
I wish I could input my throttle position sensor into the wideband controller so I could more precisely plot % TPS versus AFR. From what I see is the beginning of the EMR straight is good but seems to last too long before the E taper takes over. The taper seems to start taking effect around the 1/4 throttle or very slightly after. The NCVR has a second taper that starts around the 1/8 and last to about the 3/8 throttle. What are your thoughts?
Edited by D0T-C0M
