Jetting help Please and Thank you
Alright i have a 2007 DRZ400SM
.3+3
.MRD/SSW "open"
.UNI air filter
I got a "old" slant body FCR off a 2003 DRZ400E from what im told and this thing is in grate shape!!! "new in box" lol I have a jd jet kit on the way, was just wondering what jets to change and to what. CE was removed and connected nipples ap mod was done. . . 👍
current jetting
142 Main
65 Starter
45 Pilot
200 Main air
60 Pilot air
OBDXP clip 5 "down from the top"
Elevation: 1594 feet
Number on the side of the carb is 29F4NK12 <<< would this be off a 03 DRZ400E??? please and thank you all again
Edited by osiris07lv
Elevation:
you're going to want to start with something like;
165 main jet
45 pilot jet
100 main air jet
emn needle
clip 3
9mm float level
about 2 turns fuel screw
also,you'll probably need the e model intake manifold boot and the e model throttle cables as the sm cables are too short to work right.the head stays will need to be moved to the left side for proper cable clearance.you'll need a vacuum nipple for the intake to run the stock petcock too.
i have the same carb on my 08 drz, 3x3 full yosh system 01 drz e carb that jetting is way lean. i run all the stock jetting and a 165 main jet. i moved the metering rod to clip 5, fuel screw at 2 turns out.bike hauls ass compared to stock. you will need all the things bumtarder recommended to install it on your bike. you will not be dissapointed.
