ElginEddie Posted April 10, 2010 Hi guys, I hate to ask this but I couldn't find anything when I searched... does your chain make a buzzing sound as it spins around the counter shaft sprocket? Mine sounds like buzzing bees. It's well lubricated and tensioned so I'm thinking it's just a normal sound of the chain being driven around the sprocket. Thanks! Ed Share this post Link to post Share on other sites
terrordactyl250 Posted April 10, 2010 what size sprockets do you have. are they stock? make sure you chain is not to tight or you will wear out you sprockets real fast. this not a bicycle you dont need the chain real tight. i had a 47 or 48 in the rear and it would rub the chain runners (the white lower thing that the chain runs through next the rear sprocket) not only did it make a buzzing noise. it also wore the chain down so bad the rounded edges were flat. but to answer you question a little buzz is ok. but it wouldnt hurt to check out you front sprocket. i hope this helped. that just my 2 cents in the matter. Share this post Link to post Share on other sites
HeadTrauma Posted April 10, 2010 Make sure your chain is adjusted to ~1 5/8" of slack with the rear axle at its furthest point from the countershaft in the suspension travel. You will likely have to be sitting on the bike or have someone sitting on it to compression the suspension enough. If you set the chain slack with the bike leaned on the side stand, the chain tension will be too tight. It is suspected around here that too little chain tension is a major factor in damaged countershaft splines. Chains do make noise, but I find that mine are noisy when they are getting worn out. My chain and sprockets are still pretty good so I have to lean over the side right now to hear anything. I don't notice any noise during normal riding yet. Share this post Link to post Share on other sites
brianhare My Ride Posted April 11, 2010 [quote=HeadTrauma; It is suspected around here that too little chain tension is a major factor in damaged countershaft splines. QUOTE] OH,OH,TYPO 👍🤣 🤣🤣🙂 B Share this post Link to post Share on other sites
HeadTrauma Posted April 11, 2010 EDIT: Too little chain slack. 👍 Share this post Link to post Share on other sites
ElginEddie Posted April 11, 2010 I have a 14 tooth front sprocket (with a few hundred miles) and the stock rear sprocket. Chain is original OEM with ~1,700 miles. I'll re-check the tension ASAP. What's funny is I only hear things when I'm not wearing my helmet! I'm hoping the chain noise (along with light valvetrain ticking even after valve adjustments) are normal. I'll report back what I find with the tension readjustment. Thx! Ed Share this post Link to post Share on other sites
BRP Chaos Posted April 11, 2010 Id check the chain well, I have never noticed any chain buzz on mine and I have a quiet exhaust. Share this post Link to post Share on other sites
Memnok My Ride Posted April 11, 2010 Check the top chain slider. Mine wore through in about 2k miles and the chain was riding on the swing arm. Share this post Link to post Share on other sites
jokerflingo Posted April 11, 2010 Check the top chain slider. Mine wore through in about 2k miles and the chain was riding on the swing arm. I reckon u woulda heard that 👍 Share this post Link to post Share on other sites
