07 has bad miss when hot
I finally got a couple days off work and wanted to get the bike out the first time this spring.
Bike started easily and back fired one time and quit. Restarted and ran fine until engine got some heat in it and it started missing bad. I took it back to the garage and changed the plug and fuel, cleaned the tank filter. restarted and had the same problem. So I removed the carb and cleaned the jets and have the same problem. Any suggestions would be appreciated...👍
07 crf 450r... Yosh RS2 full exhaust with steahly flywheel weight.
