How do you separate original equipment Chain
Does anyone know how to separate an original equipment chain on a 2008 WR250R? I can't find a connecting ling. Would greatly appreciate anyone sharing their experience.
Grind the burr off a pair of pins down flush to the side plate, then press the link apart. If you have a good quality chain breaker you can just press a link apart without even grinding anything.
If you don't want to re-use it you can just cut two of the side plates with a dremmel. I usually do the grinding method as well but I couldn't separate it after that so I just cut it.
