2010 air filter
I want to share something with you guys that I noticed on my air filter cage. I removed my stock air filter and installed a filtron air filter, When I tightened the air filter cage the filter seemed like it was not seating properly. I could rotate the filter cage even after it was tightened. I took the filter back off and installed the cage without a filter and after it was tightened there was a gap between the cage and the air box. Do you think Honda did this because of the rubber gasket on there air filter? To fix my problem I ordered a PC racing pro seal air filter kit. Just something you may want to check and it might save someone a lot of money.
