Smooch2010 Posted April 11, 2010 I have a rm 125 and when i am starting it it revs its ar*e off i have had the carb off and every thing seems in order any help ?? Thanks Marc Share this post Link to post Share on other sites
crider400 Posted April 11, 2010 it revs by it self? Sounds like a air leak. Clean all the jets withhose and air compressor. St float height, could be starving for fuel.... But if it still keeps revin on its own, its an air leak. Was there any recent engine work? Share this post Link to post Share on other sites
Smooch2010 Posted April 11, 2010 it revs by it self? Sounds like a air leak. Clean all the jets withhose and air compressor. St float height, could be starving for fuel.... But if it still keeps revin on its own, its an air leak. Was there any recent engine work? Yes it revs on it on and i have also done a top end about 7 hrs agoo ! Share this post Link to post Share on other sites
crider400 Posted April 11, 2010 Did you torque al the bolts? Use brand new gaskets? Share this post Link to post Share on other sites
mihylo33 Posted April 11, 2010 Did you torque al the bolts? Use brand new gaskets? +1 check everything..... Share this post Link to post Share on other sites
Smooch2010 Posted April 12, 2010 Did you torque al the bolts? Use brand new gaskets? bolts were all torqued and all new gaskets it was fine al day yesterday and then it was like some on turn it on and it started doin it 👍 Share this post Link to post Share on other sites
mihylo33 Posted April 12, 2010 Do a leak down test. You'll find a link in the Suzuki FAQs sticky. Share this post Link to post Share on other sites
