lat19hi Posted April 11, 2010 I put a new tire on (Kenda 760) and the wheel is not on center. I followed forum advice on wheel tightening sequence. (lightly tighten one side pinch bolts, tighten axle bolt retiten pinch bolts bounce forks a few times then tighten other side pinch bolts) The manual shows the spacer having a shoulder and mine does not. Any thoughts guys? Share this post Link to post Share on other sites
lat19hi Posted April 11, 2010 Is it just me or is it a PITA to insert photos 👍 Share this post Link to post Share on other sites
rcifs Posted April 11, 2010 Looks fine. If the brakes aren't binding I don't see a reason to worry. Share this post Link to post Share on other sites
lat19hi Posted April 11, 2010 So no problem with the wheel being to the left and not centered bewtween the forks? When I was riding trails yesterday steering felt a little squirly. Hopefully it's just lack of ability. Naw it could'nt be that. Share this post Link to post Share on other sites
TeamDad Posted April 11, 2010 Make sure the speedo drive lugs engaged and that it seated completely. Share this post Link to post Share on other sites
CobbMtn03Z Posted April 11, 2010 your speedo drive is installed incorrect. twisted too far back. the tab on gear goes above tab on the fork. having below causes a bind, forcing fork leg out of position Share this post Link to post Share on other sites
lat19hi Posted April 12, 2010 Thanks, I will adjust it before my next ride. Aloha Andrew Share this post Link to post Share on other sites
