suspension question
is it just air pressure that goes in the rear shock and how much,when i pull up on it it stays up but when i sit on it doesnt come up all the way when i get off
I had a CR250 that required 290psi of nitrogen.
Air is unstable and pressure can fluctuate between a cold/hot. Nitro' is stable...it won't gain/loose any pressure.
How is the sag ?
Does it squat a lot when you sit on the bike????
Might have to crank in a round or 2 of extra preload.
Don't mess with the shock fitting, it has to be done with nitrogen in a shop. Like Old Timer said you need to adjust the preload for your weight first. If it still stays down you might need a shock rebuild.
