Sapphire Posted April 12, 2010 (edited) This is an 04' DRZ... I think its an S... not sure yet though. Anyway, the guy claims it runs great (will be riding it tonight or tommorrow night)... I am wondering what would cause the finish to come off the casing here. A buddy suggeste that bike had to get Insanely hot to make that happen... The rest of the bike looks pretty darn clean and he just plopped a new battery in it... Plus..it comes with all these accessories, which I think I would just sell off... He is "asking" 2K... I have a feeling I could get it for 1500.... sell the xtras for a couple hundred?? and have my deezer WITH E start (I've been riding a kicker for the last few days for a "trial" and am NOT a huge fan of kicking the thing over.👍 Edited April 12, 2010 by Sapphire sp. Share this post Link to post Share on other sites
465from_hell Posted April 12, 2010 I don't think the bike got really hot my guess is they sprayed it with solvent or some degreaser at some point it will do exactly that. Some of that stuff will fade colored rims and should not be used on aluminum when hot. Share this post Link to post Share on other sites
rallyDRZ Posted April 12, 2010 Don't know for sure but it looks to me like someone tried to paint it...poorly, and it's just the crappy paint job coming off. Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 Are those pieces normally just metal colored then? Not Black?? ANyone got pics of an 04 Crank case??? Share this post Link to post Share on other sites
RiD3HaRD Posted April 12, 2010 Thats what I would say. It was probably painted and it's just coming off... Share this post Link to post Share on other sites
465from_hell Posted April 12, 2010 Also if it were me I'd pull the plug and see what it looks like if wet black then oil is getting by rings or valves.I've always offered less for something I was interested in buying and most of the time they will take it.Good Luck:) Share this post Link to post Share on other sites
jones-moto-east Posted April 12, 2010 This is an 04' DRZ... I think its an S it's an E Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 I always get confused... seems one, the S or E has a better motor? Or...more powerfull anyhow... Do you guys know which is which?? How does THIS motor compare to the 2000 kicker's motor I rode this weekend...? Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 I need more opinions! Thank You!! Share this post Link to post Share on other sites
Sundog Posted April 12, 2010 (edited) Motors are almost the same. S has different cams and a 3 ply base gasket (lower compression), autodecompression built into the cams E has more aggressive cams, 1 ply base gasket, FCR carb, autodecompression built into the cams K has the more agressive cams (auto decomp), 1 ply base gasket, FCR carb, lighter flywheel, no battery/starter and a manual decompression lever and IIRC the FCR carb has a hotstart knob, kickstart Edited April 13, 2010 by Sundog Edit: K cams do have auto decompression Share this post Link to post Share on other sites
CJH Posted April 12, 2010 It looks like the head is either newer than the rest of the motor or it was off and it was re-painted. Just going by the difference in color of the jug and the head. Either way the motor was likely apart. Nothing wrong with that, just make sure everything is right with the motor before buying. I would agree that it is an E. Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 Is there a noticeable difference in the E and K power??? K sure sounds better... Share this post Link to post Share on other sites
pi3832 Posted April 12, 2010 Is there a noticeable difference in the E and K power??? K sure sounds better... I thought you said you didn't like kicking a bike? Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 Yeah...So? If it makes a noticeable difference in power I just may be able to handle it!🤣 if the bike starts relatively easy...I sure wont mind! And from all the input I've got from you guys, if I get it tuned right and jetted properly, etc...it'll start right up no prob!👍 Share this post Link to post Share on other sites
ptgarcia My Ride Posted April 12, 2010 E and kicker make the same power. Share this post Link to post Share on other sites
Sapphire Posted April 12, 2010 Someone look at there crank case and tell me if its painted black/anodized or if its metal colored?!?!?! Please! ;0) Share this post Link to post Share on other sites
ptgarcia My Ride Posted April 12, 2010 They're all bare metal. The early model bikes were a little darker but none of them were painted. Share this post Link to post Share on other sites
Sapphire Posted April 13, 2010 Thanks... so that was definitely just a bad paint job... thats good to know.... Share this post Link to post Share on other sites
Juxxtin Posted April 13, 2010 I have an E model. That dark gray color on the left lower is stock. My bet, is it has been pressure washed year after year and the oem paint is coming off around there. With that in mind, you could ask him it he greases the rear linkage ever. Also, the discoloration between the head and cylinder is completely normal. That does NOT mean they have been apart, simply means it's a used DRZ400E. Different metal composition or something, I don't know the technicals, just that it is normal. As others have said, K and E are same in power components. 👍 Share this post Link to post Share on other sites
steve_k Posted April 13, 2010 I think the kicker looked better, with less wear and tear... Share this post Link to post Share on other sites
