CEORanger Posted April 12, 2010 just bought an 04 250 EXC that has 45 hours on it and has been mostly sitting in a garage for the last few years. it even had the original tires on it still. anyways, went through the whole bike and when i took the radiator cap off there was some depsit build up and i cleaned it up, flushed the radiators and put it back together. when i run the bike and it warms up, coolant comes out of the left radiator out of the over flow tube at the top. I am guessing due to age and some of the deposits that the seals on the cap may be bad and not sealing 100% causing coolant to be pushed out the overflow once heat/pressure build up. looked at the FAQs and didnt see anything about this. i also checked the thermostat and put it in hot water and saw it was opening and closing so i can rule that out. other than that the bike is good to go but i cant go ride it until i figure this out. thanks, Jason Share this post Link to post Share on other sites
Mike in Fresno Posted April 12, 2010 you are on the right track what with the corrosion you found, Use a wire brush to clean the cap area of the rad til it feels smooth with finger tip and maybe a new cap if you cant get it clean. If that isnt it then it may be a leak in a gasket at the head or cyl pushing it out, Share this post Link to post Share on other sites
