Other than a pipe, how do I get more bottom from my 2010?
I've heard a Hot Cam Stage 1 will do the trick too.
The only thing about the stage 1 cam is that it rev's out and flattens pretty quick. It will increase bottom end. It was designed specifically for that, but excellent choice if that's all you're looking for! I'd do the re-map first and see how that works out for you.
Get it mapped you will gain bottom there (Eddie sisneros)
maybe try the insert from TUF
cheap and easy mods
Kim
What are the EFI mapping modifications? I cant find anything in the intake forum.
Also, where do I find TUF products? searching didnt give me anything...
Look at the top of this forum (sticky) tuning options
Look at the top of this forum (sticky) TUF Performance products and RHC
Kim
i just got some motor work Done at PR2. my bike is amazing now. it has low,mid,top you can lug it rev it whatever you want. i got 40hp now and it is still broad and easy to ride
so glad i did this instead of the big bore
there is a bunch of stuff you can do from them, from inexspensive to full blown motor.
ask for Jeff and he will take care of you if your interested
IF your looking for fantastic bottom end i desighned a cam that added a bunch in the lower end but it requires larger lifters and our spring kit it took absolutley nothing from the top, with the yoshimura good fuel the stock piston and no porting the bike made nearly 40 hp .
