02 cr250 torque?
does anyone know what the torque specs for the linkage and shock bolts are?
Just tore down entire bike to re-do topend and greese. 👍
The torque specs for a 2001 Cr500 are 33 ft-lbs for the upper and lower shocks and I think 66 for the pivot bolt nuts. For my Kx250 the upper and lower shock bolts are 29 ft-lbs and the linkage/tie rod bolts are 61 ft-lbs. So I'd imagine somewhere in those areas would be right for your bike. You could also probably torque to those specs until you find out what the actual torque specs are though.
