jordankyleatc350x Posted April 13, 2010 Ive got a 41mm on my 400 motor and I have a couple questions there are three jets in the bottom of the carb ones the main ones the pilot whats the other one for. I cant get it to idle and it loads up on fuel so much that it wont start after I run it a little and it gets hot. Ive got two vents at the top of my carb and they pour gas all the time so I looped them together and then i have one that pulls vacum till I give it throtle im so tired of this thing i need help Share this post Link to post Share on other sites
PBMW Posted April 13, 2010 Why do you have a 41 on a stock bore motor?? Share this post Link to post Share on other sites
Wayward Son Posted April 13, 2010 the other jet is the starter jet.its where the choke gets its fuel. what is the complete current jetting including needle code? where did the carb come from. Share this post Link to post Share on other sites
Wayward Son Posted April 13, 2010 end yes a 41mm is way too big for a stock and too big for your average mod motor. Share this post Link to post Share on other sites
jordankyleatc350x Posted April 13, 2010 Im sorry I should have explained myself better I have a 5mm stroker crank with a 95mm bore,web cams,ported head with 1mm bigger valves installed I got the carb new from trinity racing for the aplication. How do I now the needle size is it on the side. the carb does not have the tps sensor and it has a accelorator pump. Share this post Link to post Share on other sites
Wayward Son Posted April 13, 2010 post a picture of the carb. if you cant give me the info i need than i suggest calling the guys you got the carb from. Share this post Link to post Share on other sites
jordankyleatc350x Posted April 13, 2010 here are some pictures i hope they help Share this post Link to post Share on other sites
osiris07lv My Ride Posted April 13, 2010 take the top off the plate that says CR two allen bolts you'll see another allen in the center of the slide back that out abbd tip the carb upside down neddle will fall out read code on needle and what clip position counting down from top Share this post Link to post Share on other sites
Wayward Son Posted April 13, 2010 ok,now we know its a slant body fcr. Share this post Link to post Share on other sites
