needed urgently, standard piston pocket dephts
for the ex an intake side plz
tx
Edited by EtienneNXR
spelling
The guy that rebuilt my motor made a bit of a stuff up it seems, the pistons hitting the intake valves.
Mesuarement from the centre of the side? Anywhere where you have mesuarments, just tell me where its mesuared from
tx eddie
What mods? It sounds like the cam timing is off.
sounds like a simple cam timing issue to me.
this is the guy that "rebuilt" your motor with out taking the head apart?
So incorrect cam timing can cuase it? ie not having the cams perfectly lined up with those two little lines?
and not from the piston not being correct?
There are several things that can cause it. That's why I asked about mods. The most common problem is improper cam timing. The wrong piston could do it. Or bad rod bearings. An improperly built stroker engine.
So, just what was done and what parts did they use?
It had a top and bottom end rebuild 2000kms ago, motor is standard, no bb or stroker kits
So if I just get the cams lined up properly it would be ok? There are some light marks ontop the piston
incorrect cam timing or the piston being installed backward.
Thanks guys...now next problem...while trying to get the piston to the top, I didnt tension the cam chain...so its wrapped in there pretty badly...any advice on getting it unstuck??
