rmz oil problems
hey i got a 05 rmz that has all the oil building up in the stator side. i had installed a new crank so i had the motor apart but now the oil wont flow back to the clutch side. it runs just fine but you dont know how much oil is in it. it doesnt leak a drop either. anyone know whats going on here? i called quite a few shops and they have no idea.
Only the person who did the job will have an idea(not sure if you did motor), but hard to say from not seeing inside. Something IS wrong and may not last too much longer. I would definately look into it/strip motor again as its not normal.
did u put the oil pump impeller back in correctly? Have to take off the inner right side cover but u can do this with the engine still in the frame.
I wonder if a plugged transmission vent hose could cause enough of a vacuum the oil can't flow from one side to the other.....as in from one chamber to another. Probably not....just a thought.
There is a reed one way check valve that is in between the two case halfs.
It's hard to do because of the shape but maybe that was put in backwards.
Look at a microfiche and you will see it.
Just a sugestion.
