mdubpower Posted April 13, 2010 I got the bike to idle perfect but I have a new problem... When I first got the bike running I took it up the road and back and it went great. Now, the clutch will not dis-engage the engine. It is adjusted perfect and feels great. I run Amsoil 10-w40 Transmission Lube but I cant see this being the problem?!? What is the screw on the clutch case that looks like it goes into the clutch post the cable connects to? I need help! I want to ride! Share this post Link to post Share on other sites
mihylo33 Posted April 13, 2010 You need to pull the clutch cover off and inspect the clutch. look for broken or warped plates, notched basket and hub etc etc. If you don't have a service manual then get one right away before attempting any repairs. Share this post Link to post Share on other sites
