Flywheel Weight install
Just wondering what exactly are the steps involved for installing a FWW i couldn't find anything telling me the install steps just removal of the flywheel in general
remove flywheel cover
affix weight to flywheel with the means provided by the manufacturer, which you failed to mention
some replace the flywheel nut (in which case you would remove the nut and "screw" the flywheel in its place), some bolt onto the flywheel
to remove the flywheel:
remove cover
remove flywheel nut
pull flywheel with flywheel puller
the nut will require an impact, or flywheel holder, or a good large strap wrench
