mike09touring Posted June 6, 2010 ok heres the situation i have a 2000 cbr F4 600 that i just purchased . the guy i bought it from had a f3 front rim on it. i dont know what spacer or axel rod he used. i have a mint condition f4i rim . Now my question is what spacer and axel rod do i need to buy to mount the f4i rim on my F4. i belong to 2 other forums and one kid said he has a f4 with the rim conversion so it can be done i just duno how to do it...no one in the other forums has had an answer for me please H E L P!!!!👍 Share this post Link to post Share on other sites
anvilair Posted June 7, 2010 OK..... I am NO expert but I have some experience as a low buck racer and mechanic. My understanding is that since the distance between the forks is so different between the F3 and F4 in combination with the axel diameter being different as well, that most riders have deemed this an UNSAFE mod. I would do some serious research before attempting this or taking forum style advise. Best of luck! Dave Share this post Link to post Share on other sites
mike09touring Posted June 7, 2010 I am putting a F4i rim on a F4 not a F3 rim on a F4 Dave. The bike came with a F3 front rim. Share this post Link to post Share on other sites
Burrap Posted June 15, 2010 if the axel diameter is the same for the f4 and f4i and the distance between the inside of the forks is the same, then i would buy an axel for an f4 and the spacers/bearings for the f4i. i checked oem part numbers to see if any matched up, but they changed alot of the front wheel parts in 2001 but i assume the axel diameter didnt change. my buddy has an f4i, i could measure the distance between the forks and you can give me your measurement and see if you would need different spacers or not. send me a pm if your interested. but i think you definitly need the same axel that originaly went with your f4. Share this post Link to post Share on other sites
mike09touring Posted June 17, 2010 I am in queens ny. Thanks a bunch!! What year is your friends f4i? Share this post Link to post Share on other sites
frenchtoast Posted July 14, 2010 I'd just pick up a stock set of spacers and mounting hardware. Share this post Link to post Share on other sites
mshunter Posted July 31, 2010 The F4i is an injected F4. It will bolt right on. All the part numbers are the same. Check bikebandit.com and compare for yourself. Share this post Link to post Share on other sites
