switzer Posted June 7, 2010 Okay, I seen this mod about a week or so ago. Now I cannot find it anywhere. None of the links work. I just need to see how to do it?? I remember reading that the spacer is not needed anymore then I need to elongate the bolt holes. Just dont know if I need to elongate the top of the hole or the bottom of the hole. If someone knows a link for the how to. I would appreaciate it. Thanks! Share this post Link to post Share on other sites
solidjohnny Posted October 26, 2010 i did this mod a long time ago. You can figure it out by seeing which way the flywheel turns when the engine is running. Then you want to advance the timing so you want to move the sensor accordingly. Its easy! Share this post Link to post Share on other sites
bendawg62 Posted October 26, 2010 try this - http://www.dirtbikemods.com/motorcycles/index.php?option=com_content&view=category&layout=blog&id=13&Itemid=91 Share this post Link to post Share on other sites
