FMF Q2 exhaust with JD Jet kit (advice needed) ?
42 pilot, 165 main, Red Needle, 5th clip, fuel screw 2 1/2 turns.
I'm assuming your in a 1000 foot or so altitude?
currently I have the
42 pilot
red needle in 5th clip
158 main
I will bump the main up to 165 and start from there. Thanks for the suggestion.
I've been using a 165 since I did all of the mods. You should be good to go with that main. Also, I use 2 1/4 turns in the winter and 2 3/4 in the summer. If I run 2 3/4 in the winter, I get a lot of decel pop. Good luck.
