jetting for standard
due to the adverse conditions in the uk am going to put air box snorkel back as ive just had motor apart and the bore was scored from dirt going in there,whats the recommened jetting with this back and baffle in(too loud with it removed) can the power up needle still be fitted, any recomendations?
The dirt should never make it past the filter unless you have an air leak.
If you want the bike quiet keep the tail pipe baffle.
The intake baffle should be removed though. It's just too restrictive. Keeping it in will be like having a governor on the bike. Not like these bikes can rev but it will limit it's top end.
I would think the stock needle would be good for this set up. I'd start with a 118 main since I ran a modified baffle for a while with that and know it's safe for the bike. You might end up 1 or 2 sizes smaller with the stock baffle.
Good luck!
