easy Timing question!
How many "pins" in the cam chain should be between the upper timing marks on the cam sprockets on an 07 KX250F at TDC? my lower punch marks appear to be even with the top of the cyl. head when 11 pins separate the two upper cam marks but I have noticed on the older kawasaki wrench report PDF that it appears that older KX250F models should have 12 pins separating the upper marks.
anyone know about this?
I wouldnt think too much of it, I didnt check mine and it seems good so far. Is it new chain? do you have the tensioner on? just make sure your tensioner isnt extended too far if it is you need a new chain! Get the timing perfecct and get to riding.
