drz 400s Afterburn
There is a bracket on the side of your carb with two screws in it, remove the screws (be carful because there is a spring behind the bracket) and there is a small diaphram sometimes the diaphram will have a small hole or tear and will cause it to pop on decel. When you pull it out make sure to hold it up to light, The holes can be very small. Good luck
