Rekluse z-start pro
G'day,
Does anyone here have any expirence with these clutches on YZF's. I have noticed that the bike has lost top end speed. Do you know how I can fix this problem? Clutch has been well maintained and does not appear to be slipping up top.
Thanks
I just got one for my 08 YZF250. Have you checked your gap on the pressure plate? If that checks out, make sure your clutch cable adjuster is adjusted properly. The only way you could lose top speed is if the clutch is slipping. There is far more load on your clutch in the higher gears, so it could definately be slipping if anything is out of adjustment.
