2003 trx250ex transfer case noise?
couldnt find anything via extensive google search, obviously not a common problem but
this thing makes a strange swoosh swoosh sound when moving, its not with RPM, but with vehicle speed, all speeds...kinda gets louder, the faster you go
throttle on/off dont matter
sounds like, if you were to take some cardboard and scrape it on the driveway or street w/e ..lol best way to describe it 🙂 like cardboard on cement
doesnt sound like metal to metal
drives fine, its definitely coming from the transfer case, left side
just wondering what it might be? before i take it apart this winter
Is this an engine noise or a frame/drivetrain noise? If you turn the engine off and coast down a hill, does it still make the same noise?
There is no "transfer case" on this 2wd quad, so I assume you may be refering to the rear final drive of the shaft drive system (????). The brakes are inside this hub, so it might be that you have a brake shoe rubbing?
Or is the noise up in the transmission area???
took it out for 2 hour spin and it sounds different....
more clunky slappy now....
coming from the motor, transmission area, left side of quad
coast its almost not noticeable, and gets louder under acceleration 0-1/4 throttle and only slightly more louder 1/4-full throttle
seems to make the noise with vehicle speed, not rpm
not sure how to engage clutch to stop the motor from engine braking, while coasting, cept keep it in a high gear, but ya...louder under acceleration
Just stop at the top of a hill, put it in neutral and let it roll down with the motor off. That will insure that it isn't frame/drivetrain noise vs engine noise.
There are very bulletproof engines/transmissions! If engine, does the noise sound down low or up high. Have you adjusted your valves lately?
  • 3 weeks later...
