KX450f Mid Range Cutting Out. Jetting Problem? Please help! BUYING TOMORROW!
Hey guys,
I might be picking up an 06 KXF450f tomorrow that is supposedly in great condition minus some minor carb/jetting issues. The current owner says the bike runs find at wide open but cuts out in the mid range. He says it is a jetting issue.
1. Does this sound like a jetting issue and based on the mods below what will I need to do to correct this?
2. Could it be anything else major? Valves etc?
Mods are a two brothers exhaust, air filter and Hinson clutch and basket.
Any help/advice on this would be greatly appreciated!
-Peter
not enough info to give even a guess.
could be jetting.
could be worn parts.
could be ignition related.
could be cam timing.
coudl be lots of things.
Is there any other info I can get to help someone maybe have an idea of what it is? Is there anything I should check on the bike when I look at it to determine what it could be? Without tearing it apart at the seller's house?
Thanks!
