Anyone revalve a kdx shock?
I have a 2004 kdx 220. I know the forks don't have shim stacks and there's not much that can be done with the stock components, but I'd like to revalve the shock. Anyone know what kind of stack to put in there? I'm 180lbs, fast C class harescrambler, riding rough new england terrain: rocks, roots, tight single track. I'm looking to get a lot more plushness.
They don't? I was under the impression that they did or is that just the race tech stuff?
Nope, the stock setup is a check valve which consists of a washer with a spring. I spoke with Jeff Fredette about it and he said that they tried all kinds of things, different washers, changing the hole size, even grinding the spring to change the rate, and that nothing they did helped all that much.
If you want a true cartridge in the front, you have to buy the racetech stuff.
