2007 PW50 wont idle with choke off
My sons PW50 starts up and runs fine with the choke on he can ride it all day like that. When I cut the choke off the bike will keep running fine as long as your on the gas and as soon as you stop and let it idle it cuts off. I know its a carb issue but does anyone know what jet is clogged causing this or anything else it may be? Thanks for any help you can offer.
The PW jets have tiny openings......Even the main. I cleaned the carbs between motos when we raced them. Carb cleaning should be in your normal routine and you will have no problems.
