Easy jetting confirmation?
1) 2002 Honda CRF450R
2) 90's, 1000 Ft, easy trail riding
3) FMF PowerCore 4 w/ Powerbomb, Hotcam, motor possibly bored out to 465, motor possibly has a high compression piston, motor possibly has SS valves
4) 175 main, 42 pilot, OBEKR needle, 4th clip down
5) Hard to start, backfiring
6) Backfiring seems to possibly go away slightly when engine is hot.
The jets for my bike at my conditions should be 172 main, and 45 pilot. So I'm thinking of ordering those, but I don't know if it will work fine with my motor setup.
Just need someone to tell me if it's a good idea or not..
Thanks,
Alex
Check the fuel screw/pilot jet setup.
Fuel Screw/Pilot Jet
Fuel screw settings in the 'book' are recommended starting points. Every bike is different, as is the temp and altitude. Set the screw according to this method. Do it with the bike fully heated up.
Gently turn the screw all the way in. Now back it out two turns. Start the bike and fully warm it up, go for a 10 minute ride. Set the idle to speed to 1,500~1,800 RPM as best you can (I know, without a tach this is tough, just set it to were it idles relatively smoothly). Once warmed, slow the idle to the lowest possible speed.
*** When turning the fuel screw, keep an accurate 'count' of the amount you are turning it and record it in case you have to reset it for some reason. Makes life easier when you can just set it from notes Vs. going through the procedure again.***
Turn the screw in until the idle becomes rough or the bike stalls.
if it stalled, open the screw about 1/4 more turn. Restart it and slowly screw it in till you can just perceive a change.
If the screw can be turned all the way in and the bike still idles perfectly and does not stall, then you need to go down a size in pilot jet.
Now very slowly, open the fuel screw till the idle is smooth. Blip the throttle, let the bike return to an idle, wait say ten seconds. Confirm it is the same smooth idle.
If the screw has to be opened more than 3 turns to get a smooth idle, you need to go up a size in pilot jet.
If you find it does not stall with the larger jet but has to be open more than three turns with the smaller pilot jet, put the larger one in and set the fuel screw at 1/2 turn.
If the idle speed increased, adjust the idle speed knob to return the bike to a real slow idle speed. You must then re-visit the fuel screw. Keep doing this till the fuel screw is opened just enough to provide a nice steady idle at the lowest possible RPM. Once this is done, increase the idle speed to the normal one for your bike, typically about 1,800 rpm, but go by the spec in your manual.
Be sure to keep notes of your settings. You may find you need to make a change, say if you're riding in the mountains or down at the beach. Returning home, it is a simple matter of referring to your notes to restore things.
Mmk, I'll order the stock jets. We'll see from there. I just hate to take everything apart, spend money on new jets, get everything put back together, and find out I have to change jets. Lol. That's why I wanna get everything right the first time. I have to take the whole carb out the bike to change the jets dangit. Lol.
Should be able to loosen the clamps and rotate the carb to get to the plug on the bottom of the carb and change the pilot and main jets.
I'd start with that 45 pilot, then ride and see how it runs mid-top.
**make all changes and observations when the bike is fully warmed up**
I'd start with that 45 pilot, then ride and see how it runs mid-top. A bigger bore than stock would require a richer mixture, see how the 175 main that's in it works before going leaner.
The 175 main is snapped in two. I was taking it out to clean my jets out, and that's when I noticed that I had the wrong sizes in the first place.
