xr80/100 manual good enough for xr200 (2000)
Plus the kick start gear/return spring set-up, cam/ head set-up, tranny, oil spanner, clutch set-up, most likely every torque reference, and all the info like what size pilot and main jets, etc.
all I needed was a couple torque values and a diagram for the pulse generator I've found all the honda XR's I've worked on use basically the same values
I found what I was looking for, thanks for the help though
