YZ250F 07 vs 08 big bore kits
I'm in the market for a big bore kit for my sons 2008YZ250F.
I found 2 kits on ebay (YZ 250F JE 290CC BIG BORE CYLINDER KIT)
that seem to be identical except one says it's for 2001-07($379.95)
and the other says it's for 2001-09($429.99).
How can this be? Is there a difference between 07 and 08?
Well, I looked up the OME prt#'s for the rings, piston and cylinder.
The rings and cylinder part #'s for 07 are the same as 08 but the
pistons are not; 07 - 5NL-11633-00-00
08 - 5XC-11631-00-00
I also checked the part numbers for the cams, crank shaft and valves.
They all jive from 07 to 08. The cylinder head assemblys even have
the same part #.
What gives? Should I cheap-out or spend the extra $50 to be safe?
Maybe some one can enlighten me.
thanx joey
thanks supa.
I e-mailed the seller on ebay and this is what he said;
"They just havent been updating the product years from the manufacture. they accually fit up to the 2010."
thanx joey
