timing
I'm not 100% sure about how timing is set on the 660 Raptors, but changing the Woodruff key will not affect timing unless it is an offset key. Timing is usually changed by moving the stator though on some models this is not possible. If the crank was rotated with the flywheel off, it won't matter. That is key's job. It keeps the flywheel aligned with the crank.
