yz 125 shifter problem
I just bought a 2004 yamaha yz 125, works awesome. but i down shifted once a bit hard and now it doesn't go into first gear. normally if you push the shifter down if you are in 2nd it will go to first but now it just goes into neutral. now neutral is half way between 1 and 2. as i push it down its hitting on the frame. i looked at it and noticed the shift lever was a little loose, im wondering if when i down shifted if the shifter came a bit loose so now it hits the frame and only shifts down half a shift instead of a full shift. Im hoping this is the case and not that my first gear is gone, but i have no idea. If anyone can help me out or tell me how to fix this i would really appreciate it.
