interested in a cr144?
I have a 2002 CR 125 ported, comes with a 144 ported for max horsepower( uninstalled awaiting a piston) 34mm carb, 36mm and 38mm carb. included. and a spare stock 125 cylinder so there's 3 total. has a six speed gear box instead of 5, suspension is done by fine line set up for 140-150 lb int. new tires hydraulic clutch, fat bars, pro circuit pipe. the motor is actually a 96 motor that I rebuilt and installed last year, bike has very little hrs on it and everything is in order.you will not find anything broken or rigged nor will you be buying a piece of someone else broken junk. I am located in orange county California. 1800.00 not interested in any trades right now. picture is available on My garage or I can send it to you email is skillet_5@msn.com
www.dsmsmotorsports.net
