YZ250F How to tell if your bike is running rich or lean
well usually just by the sound of the bike in general can give a pretty good idea. if your pulling out of tight corners and it bogs and sounds really chummy then its rich but if it sounds like its surging and has really high rpms then it is lean. also the spark plug will work if you check it right. look at your owners manual under the carburater adjustments section and you should find alot of stuff you need to know. hope this helps
