02 vs 03 cr250
Don't think I've ever heard anyone say they prefer the '02 over an '03. Here is what motor changes were made (from here):
NEW FOR 2003:
New cylinder porting.
New eight-petal reed valve.
New air intake system offers straighter alignment to produce more direct airflow.
Redesigned number plate and inner duct.
New foam gasket between airbox and air boot for better sealing and airflow management.
New works-shaped expansion chamber.
New ignition timing settings help broaden the engine's powerband.
ENGINE:
Air intake boot is reshaped for more direct airflow, contributing to strong low-speed engine performance.
Five-speed close-ratio transmission features thicker second and third gears.
Awesome, so anything from 02-07 would work. out of the those yr motors which would you guys recommend the most ?...i had an 02 and it gernaded so, instead of a whole rebuild looking to buy a new motor. any suggestions ?
Thanks for all the help,
John
