Is This Carb any good?
If it is the same as the carb that is on the KLR 650 then yes it can be made to work on the DRZ 400 . It wont be as good as the FCR , but it will be better than the standard carb . Many people have done this conversion and if you do some thread searches , you should find the info you need , greg
It was a mod used by some people a couple of years ago, lot of posts here about the issue (search for cvk 40 ).
I wouldn't bother to do it, but you will get a bit more grunt than with the bsr 36.
