Antifreeze leaking from shift rod.
I have a 2005 CRF250R and just changed the piston and valves, went riding the other day and noticed that after putting on the stand in garage that antifreeze was on the floor in with the trans fluid that has been leaking since I bought the bike. Looked at everything to see where it was coming from and noticed it was coming out of the shift rod seal with the trans fluid. The only logic I can come up with is either the head or cylinder gasket got messed up or something with the water pump, but that would leak into the oil right? Any suggestions would be much appreciated.
