valve adjustment, wont idle now
let my just start by venting I absolutely hate this bike...and would burn it to the ground if i could afford it
but i need to get it running for my gf...
had the bike for a year now, bike ran decent, took a while to get the jetting right. did a valve adjustment to see if i could get it better now the ****ing thing wont idle, i got either super bad hanging idle and just dies. rechecked valves they are good, hot start is good, cant find any air leaks. what are my other possiblities??
If there's no air leaks then your fuel screw needs to be turnd out, if it's in to far
it's to lean and will high idle. The CFR150's like to be on the rich side, on the fuel screw and the pilot jet. I hope this helps.
