pro circuit vs. bbr,
  • 2 weeks later...
anyone have any comments on this?
Both are good quality pipes ive had both . but not on a 230. And it depends on which bbr pipe you are looking at as well. The less expensive bbr pipe worked well on my 150f but is not a stainless steel header. it's a ceramic pipe. Good performing pipe but will rust after awhile [ just the pipe , the silencer is alum]and needs to be painted heat proof black or silver after a while . Not a biggie. The procircut is a stainless pipe and alum silencer. A Dsection bbr is stainless but much more expensive. I would prob go with the procircut t4 . Its good quality , stainless and alum, and not priced too bad.
BBR and the ProCircuit are great pipes... I run both... I have a pro circuit on a 150 and a 230... My race bikes both run bbr pipes... torque curves are both great... you can't lose either way... BBR does put out a higher dyno number... but less than a 5% difference...
