XR rebuild help
Hello Everybody,
I am in the process of rebuilding my 98 xr400. Because the swing arm bolt wa so frozen I ended up cutting it out with a die grinder only after drilling it out many times to decrease the wall thickness. Anyways off the motor went to the machine shop for a bore and now its about time to begin rebuilding. I orders new swing arm bearings and bushings from pivot works. My first question is when I cut out the swing arm I cut through the small bushing between the motorcase and the swingarm where they meet. I cannot find the part number anywhere and was wondering if anyone had any suggestions?
Thanks,
Dan
