Tire help
I have an 08 TE450 with the Michelin Enduro Competition III rear tire in the 140/80-18 size. I want to replace it with the Moto-Z Tractionator Enduro S/T. I know that some of the Michelin tires are sized strange. Is my Michelin one of them? What size Moto-Z should I get, the 120/90-18 or 130/90-18.
You wont go wrong with the Motoz, they are #1 imho. With regards to size it would depend on the predominance of the riding you do. If you do mostly ST stuff then go for the 120 as it will turn more readily, the motoz can be run vey low psi for desert 6-8 psi without pinch flats etc. If you are mostly desert and wide open space riding I would get the 130. Good luck
