runs ok then just dies
I have a klx300r 05 it was running ok it would start everytime on the second kick. Now its hard to start and when it does it will run for a bit then die. after i start it and take of it will run fine for a mile then it just starts cutting out and eventually dies, then wont start. Fuels fresh, valves are within tolerance. I pulled the plug after it died the last time to see if it was wet to see if it flooded out but plug was dry. I used to start it with the choke on but now if i pull the choke it won't start at all. I can't figure it. Its like it just stops getting gas, but when i drain the bowl gas drains from the carb. pretty frustrated at this point. PLEASE HELP.
