crf450 kick start noisy help!!!!!!!!!!!
my kick start sound like its trying to locate even when it is in the idle position the spring recall is working and there is about 30mm play till it locate when u start her up im a bit baffled can anyone help. its an 05
ive found the problem i striiped it down and the kickstart stop behind the shaft has the top broken off £3.50 from my local dealer . it is just a little piece of metal fixed to the casing that allows the kickstart to stay in an idle position while running . due to the the bracket bieng broken the kickstart was travelling to far forward after start up hence the noise.
