How about this shock shim stack?
I found this on the TT forums:
For a 2005 kdx (mine is a 2004)
Compression
12mm shims
(8).20x38
.10x30
.12x25
.30x36
.30x34
.30x32
.30x30
.30x28
.30x25
.30x22
.30x19
4.5x41 plate
.8X15.5
This would be a two stage stack, correct?
I have too much high speed damping and I still have deflection and harshness with the clickers all the way out. Correct me if I'm wrong, but I believe the tapered stack at the bottom is the HSC, so I would remove a few of those to get some plushness, right? Can anyone give me a suggestion before I just guess and take some out myself? I've never done this before! I am a 180lb C class harescramble rider, racing in the northeast on gnarly roots, rocks, and other annoying crap.
Edited by Acmesalute76
i think you wrote the stack down wrong check it again
I copy/pasted from this thread:
https://thumpertalk.com/forum/showthread.php?t=630069
I have not yet taken it apart to measure it myself. I want to have a clue as to what I'm doing when I do.
EDIT: You are right, one of the posts was formatted wrong and I copied it over. I corrected the original post.
