DR350S Electrical Part Duex
ok...
I am having some erratic weak spark issues. I can put my finger on the end of the spark plug and kick it and may feel it one time, but the next time I get nothing..
Things I have check/changed so far...
1) CDI- I sent the CDI to a helpful friend to try on bike (fired right up Thanks Madhu)
2) Tried 4 Different Coils | 3 different caps - no difference
3) Bypassed Key Switch (Hooked Gray to Brown, Hooked Red to Orange) - no difference
4) Unhooked Kill Switch - same response
5) Disconnected every no essential plug - same resp
6) Ohm Stator - Ohms out perfectly (pickup - 220, primary 319)
7) Changed the Pickup - no change
8) Bypassed Kick Stand Switch (Grounded)
9) Bypassed Nuetral (Grounded)
So I am at a loss, I checked grounds, changed plugs...
The only weird thing I can't get passed is in the wiring schematic
its showing three wires going into the coil.
(BW - Ground)
(W/BL - Power)
and a (B/BL) I do not have this wire..HELP!!!­čśĆ
have you checked to make sure the cdi power coil is actually outputing voltage? I think its supposed to be ~100 VAC out put. At kicking speeds its going to be just a spike on an analog meter.
you would check this by testing the white and brown bullet connector wires from the stator wiring plugs.
├Ś
├Ś
